Bimmerfest - BMW Forums - View Single Post - Engine emergency
Old 12-18-2012, 06:28 PM
SD ///M4's Avatar
SD ///M4 SD ///M4 is offline
(prev. SD335is & SDZ4MR)
Mein Auto: 2016 M4 Coupe | 2006 Z4MR
The under body cover is held on by a bunch of 8mm screws, about 22-24 IIRC. A couple of the screws are actually on the side of the wheel well housing and may not be readily apparent.
You'll have to put the car up on jacks (or on a lift if you're lucky!). Use a power screwdriver or a drill bit adapter in an electric drill to make it a lot easier to unscrew/rescrew them. You may be able to start at the front and remove enough screws to pull the cover down and hopefully the light cover will slide down the cover to the front.
Good luck!
- Tom
His: 2016 M4 Coupe | Sakhir Orange Metallic | Black Full Merino Leather | CF Trim | M DCT | Adaptive M Suspension | 19" Black Alloy Wheels | ZEC | ZLP | ZDB | MPE | ED 5/13/16
Hers: 2011 335is Couipe | Le Mans Blue Metallic | Black Dakota Leather | Dark Glacier Aluminum | 6MT | ED 5/12/11
Also His: 2006 Z4 Roadster (E85) | Interlagos Blue Metallic | Black Extended Nappa Leather | Carbon Leather Trim | Purchased 7/19/12
