Bimmerfest - BMW Forums - View Single Post - Oil light comes on while idle
Old 12-19-2012, 08:35 AM
525iclassicguy 525iclassicguy is offline
Mein Auto: 89 525i BMW
I can't really get in to detail but im going to tell you exactly wats going on ........say I take a ride at first everything seems good no issues. But when the oil start to flow and the car warms up as I'm driving first gear, second gear, third gear, then I'm come to a red light wen I take the car out of gear and switch it to neutral the car idles ruff and vibrates the low on oil light blinks as if the car is low on oil but its not the longer you drive the car the worst the idle get when you take it out of gear then it's starts to shut off wen in neutral after a while so I pop the hood to see wats going on and light smoke is coming for the side where the valve, spark plugs, oil filter etc are located and the car is leaking oil after I did the replacements....????the car went from overheating to this issue
