Bimmerfest - BMW Forums - View Single Post - New Owner 08 E90M3
Old 12-19-2012, 09:39 AM
thekurgan's Avatar
thekurgan thekurgan is offline
Bad Lieutenant
Mein Auto: S62B50 Powered
Originally Posted by IndyMike View Post
Nice snag!
I'm sure I'm in the minority, but I actually like the look of the sedan more than the coupe.
How do you like the manual transmission?
Seems to be a common statement that the clutch is exceptionally light, and finding the gateways for gears 1 - 3 take a little getting used to, particularly in earlier models and on cold starts.
From what I've read about the clutch, there was a compression return spring changed sometime in 09, so my clutch feels just right to me. I've had to many BMW manual (ZF and Getrag) transmissions, I'm used to their feel. Gears 1->2 are separated by quite a distance ratio-wise, the rest are smooth; I like the ultimate control over gear choices that a manual provides.
Ilse
2002 E39 M5 / TiAg / Tubi Rumore / E60 SSK / Blanton 3.45:1 7 disc 40/100% locking diff / NCS Coding / Coby Alcantara / StrongStrut STB
Bruna
2000 M52TU E36/7 Z3 Roadster Schwartz*3 / Rogue RSM / Rogue Trans Mounts / E36M3 FCAB / Beisan VANOS Seals
BMWCCA #453648
