Old 12-20-2012, 06:24 PM
bimmernut1 bimmernut1 is offline
Mein Auto: Porsche, BMW
I was going to say battery until you said it stalled on the highway. I'd now bet it's the alternator. If you have a battery tender, charge the battery up overnight. Check the voltage with a voltmeter the next morning. I would expect to see 12.5 to 12.7 volts. Then start the car and measure the voltage at the jumper posts while running. Keep the voltmeter leads away from the fan. The alternator should be able to run the voltage up to around 14.3 volts. If not I'd first have a shop run a load test on the battery. If the battery shows good, check the alternator.
1979 Porsche Tobacco Metallic 911SC
1996 Porsche Guards Red 993 C4S
2005 Porsche 996 Turbo S
2003 BMW Ti Silver M5
2013 BMW X3 35i Carbon Black M-Sport
