It's been a long time since I had that car, but it was in the left side of the trunk behind the removable trim piece...
There was a vertical connector in there...
With the vehicle running and radio on wiggle the connectors down there. And you should be lucky enough to repeat the symptom
Remove the connector and clean with wd40 and reinstall
