Bimmerfest - BMW Forums - View Single Post - Strange codes?
Thread: Strange codes?
Old 12-24-2012, 01:43 PM
Steve530 Steve530 is offline
Mein Auto: 2001 530i
Originally Posted by E39 touring View Post
I had the test done as I had a misfire (which I haven't fixed ) the codes that I mentioned @ the start of this thread came up and I was curious as I knew then I had never seen the sensors.
The service lights were reset as I had done oil/filter change.
I have been too busy to fix the misfire which I believe is a coil pack,have a spare waiting to fit.
Will post photo of exhaust manifolds I anyone is interested.
Merry Xmas.
Yea, that's interesting. You'd think they would have handled that better in the software.
BTW, I had misfire codes last week after inadvertently disconnecting a hose on the CCV. So a vacuum leak can cause a misfire. And vacuum leaks are common. Of course, a bad coil can, too.
pshovest is writing about misfire with fuel shutoff. I think the DME shuts off the fuel in cases of sonsistent misfire to prevent unburned fuel from overloading the catalyst.
Steve
2001 530i/5 S+P CDV delete/Akebono ceramic pads
M5 SSK/RedLine MTL/M5 rear sway bar/Bilstein HD
OSRAM CBI
BMWCCA Member #337964
