Bimmerfest - BMW Forums - View Single Post - slight throbbing in gear knob
Old 12-28-2012, 05:39 PM
vandyboy vandyboy is offline
Mein Auto: 01 325i automatikgetriebe
Originally Posted by smolck View Post
Did you replace the trans mounts? Is the exhaust properly reattached? Did you replace the rubber bushing the tail of the shifter mount sets in? What about the shifter itself? Is it mounted proper? More info needed.
Could also be bad motor mounts.
Sent from my One X using Bimmer App
Could be any or all of the above, which happened to me with my E30. Probably engine or trans mounts. Also, the drive shaft could cause vibration.
