Old 12-28-2012, 07:40 PM
HerbP HerbP is offline
Have your battery load tested while you have it out. It must be fully charged to determine if the battery has a problem. If the battery is shot, a new battery with a fresh charge might fix the problem. The car will go into a load shed if the battery is weak. A fresh charge will not fix problems, if a cell is going bad.
Good Luck!
