Hello Joy & all,
I have checked the fuses externally & they are ok. There is battery voltage on both sides of the fuses with the ignition switched on.
There is only 1.1volts found at terminal 5 of the Round Pinned Plug to the Transmission Solenoid Valve Block in the Transmission. Voltages found at all of the pins are as follows;
Pin 1 = 1.1volts
Pin 2 = 0volts
Pin 3 = 0volts
Pin 4 = 1.21volts
Pin 5 = 1.1volts
Pin 6 = 1.46volts
Pin 7 = 0volts
Pin 8 = 1.22volts
Pin 9 = 1.22volts
Pin 10 = 1.46volts
Pin 11 = 0volts
Pin 12 = 0.8volts
Pin 13 = 4.98volts
Pin 14 = 0volts
Pin 15 = 0volts
Pin 16 = 0.8volts
What voltage should Terminal 5 have?
Can you draw any conclusions from this?
Can you help me with Electrical schematics for this car. The closest I have is for a 95 model & a ZF 5HP-19 Transmission,
Cheers Clive.
