Old 12-29-2012, 06:52 PM
drivinfaster's Avatar
Mein Auto: rescued bmw's
no, the vc gasket is different than the intake manifold gaskets.
as far as threaded, the m52 s/b a threaded design. i believe only the early models used non-threaded starters.
i have yet to see a nut and bolt set up on the m50, but i have seen plenty on the m30, m20....that's all they ever had...
the valve cover gasket set does not come with the rubber grommets needed for around the bolts. you'll need those as well.
df
