Bimmerfest - BMW Forums - View Single Post - If you had 3,000 (US) to spend on you "Wife"
Old 12-29-2012, 07:10 PM
jmansour jmansour is offline
Mein Auto: 04 325i -5spd black/black
Originally Posted by smolck View Post
The responsible thing to do would be cover ALL maintenance items first. Cooling system, o2 sensors, new fuel pump, air filter, cabin filter, fuel filter, control arms and bushings, rtabs, diff and trans fluids, belts, pulleys, and the list goes on and on.
Once done, you should have enough to buy some sway bars which are the best mod you can do.
Sent from my One X using Bimmer App
Yah I got a few things I should update to be safe in the future. But why would I do cooling system? My car NEVER runs temp needle in the middle (12 o clock) unless Im sitting in traffic forever or not moving at all... or flying around in 2nd gear. Most of the time Its right above a 1/3 of the gauge. (11:30ish) I left In the heat of south florida and came back up to ga and it held that temp pretty nice... by the time I got back it was at like (11:40) Id say the cooling is the last thing Id be worried about???
Originally Posted by av98 View Post
Then buy the MR2 and Miata with the money left over from DIY maintenance
Then I wont have money to mod em
