Old 12-30-2012, 03:23 PM
edognight edognight is offline
Mein Auto: 1997 e38. schwartzx2
1997 e38 no headlights, no start.
I need some help!
I'll recap:
Bought a basketcase that the owner drove to a shop, wouldn't start, and decided to sell. The key wouldn't turn, and it wouldn't start. He did drive it there. I buy for cheap.
Took my tools, and took the steering clamshells apart. separated ignition switch and turned with a screwdriver, and it started right up. Let engine run with heat on max and the ignition key park lock came unstuck. Happy day.
Drove around, and the tire was so flat spotted and frozen, it wouldn't roll. Shut it off, and had it towed to my house.
Went to start it again after tow, and nothing. It had just run an hour before. Instruments work, radio, everything inside but the headlights, and the car wont start.
So: key in ignition, screwdriver in switch and no start, and no headlights, but everything else works.
Any help appreciated!
Had battery tested, its fine, but not the one the car calls for, the previous owner put it in because the stock one was toast. It is 750 CCA and tests fine with a load test. It did start the car before, but not now.
