12-30-2012, 11:15 PM
Mein Auto: 2013 BMW 328i
Originally Posted by boltjaM3s
Just to clarify:
There is only 1 "station playlist" and it's called the Radio Presets screen. Once on that screen, you can add up to 40 stations mixed from all sources (AM, FM, SAT, HD) in any order you like. There are then three tricks you need to know:
1. Hover over the first station on the Radio Presets screen (red box around the first station on your list) and then press + hold one of the 1-8 buttons.
2. Using the iDrive controller, push the controller to the left (don't spin the dial, push the controller) so that the Radio Presets screen retracts and you're left on the Radio mode screen.
3. Hit the Nav button to bring up the map or whatever you like as your default screen display.
Once you have created your 40 favorites on the Presets screen, made a single 1-8 shortcut to the first station on that list, and 'tucked' away the Presets menu, you can tap that 1-8 shortcut button which will jump you to the first station on the list and then let you scroll through all 40 stations on your steering wheel and the head up display.
BJ
Thanks BJ for taking so much of your time to help the new owners here. Several hours from now, I will be picking-up our new 328i. I have printed several of your savvy answers. That will save us all a lot of time and frustration.
Hugh
