Old 12-31-2012, 07:53 AM
Snipe656 Snipe656 is offline
Mein Auto: 2009 335d
Originally Posted by KeithS View Post
It's not uncommon to need a top off once a year once the weather turns cold. There are always minor losses of coolant from presssure burping, especially in the warmer weather. Then when it gets cold and the level gets a little lower due to contraction, you get the low level warning.
Yes the dealer is suppose to check this during regular service but then it's suppose to be checked cold, and they are doing it hot.
Why would the overflow tank not be able to handle that? Or do these cars not have an overflow? Just wondering because I never have had to add coolant to a vehicle unless I had a leak or something worse that was consuming it. But I also have not spent extended periods of time in what most would classify as cold weather.
--Admiral Aaron Rouse
