Old 12-31-2012, 09:37 AM
doru's Avatar
doru doru is offline
Mein Auto: 2003 530iA
The difference between the car "level" and the ATF pan "level" is minimal (I believe around or below 1°), which will not affect the ATF volume much. If you observe the Bentley for the correct temp, there is still some +/- tolerance. It's not pharmacy.
When i did my ATF change, I was also paranoid about this. Once I had my car on stands, i had a level between the front & rear stands (the leveling benchmark was a string at same height between the said jackstands, and then placed the level on the string - all was OK). Then, I placed one of those magnetic levels on the pan. It was very close to the big level.
That's probably why the TIS mention to "get the car level".
0.02
Looking for a DIY? Parts? Check this out, it might be your ticket
TMS underdrive pullies - Stewart WP - PSS9 - Beisan Vanos seals - Zimmerman cross-drilled & Akebono Euro - Deka 649 MF - 55w HID headlights - 35w HID foglights - Hualigan double din - ACS (rep) alu pedals - Euro central storage console - Breyton Magic Racing staggered wheels - M5 bumper - M5 steering wheel - Tint
Stable: e39 M54, e53 N62 & Tribby
