Old 12-31-2012, 04:06 PM
NZ BMW NZ BMW is offline
Mein Auto: 2007 X5
I stand corrected - I popped both the back door cards off and there is evidence of water making its way into the cabin via the vapor barrier. Mine was actually in pretty good condition, with only some small parts coming away from the door. Looking at the right rear door, someone had been in there before to fix something - one of the screws on the airbag was actually lose... there was also smearings of whatever was used to seal the barrier outside the vapor barrier.
Based on this I just silicone'd the hell out of the areas that were lose - it will cure within 24 hours so then I will do a water test.
