01-01-2013, 01:05 PM
Mein Auto: E53 4.4i X5
Sounds like you have a dilemma! It all depends if the extras are worth it to you I suppose. There is a lot of stuff on mine I just never use but I had to have when I bought it..
Also, the X5 does not have the under bonet round connector like your 740 would have had. The only means of connection is the OBD under dash on the X5's and realistically you only need to see simplistic results off a code reader, ie pending codes, stored codes and obviously fuel trims can give a big picture of how the engine is performing without fault codes.
Good luck on your decision.
