Bimmerfest - BMW Forums - View Single Post - E34 M30/M50 Engine Swap
Old 01-03-2013, 09:07 AM
Banned
Mein Auto: car
Find the o2 sensors relay. Better in the long run. Keep pulling relays and checking for the error code. The ects is under the intake manofold, you must check the bentley manual. The icv is under the throttle body, remove the alternator ducting, key2 the ignition, the reach to the icv and touch it, if it buzzes to the touch, then it is most probably ok.
