Bimmerfest - BMW Forums - View Single Post - How do I open my trunk? No power.
Old 01-04-2013, 09:11 AM
Cam kindly posted this today:
These threads have been beating to death haha!
OK, if you turn the key manually and the door does not open, then your door tumbler is frozen from years of non-use.
Anyway, the quickest way to solve the problem is:
- Jack the Left Front up (no need to remove the wheel), support with jackstand for safety.
Or rest the wheel down on a wood ramps etc.
- Under the car is the starter motor. Look for the RED cable feeding the starter motor.
- Connect Red to Red (from donor battery)
- Ground is ground.
- Then hit the remote. You will likely need an assistant for this job.
The location of the Red terminal is at the same area as the aft part of the tire. Locate the aft part of the tire and move inward, you will see it:
