Old 01-04-2013, 09:12 AM
RJK740iL RJK740iL is offline
Send a message via AIM to RJK740iL
Mein Auto: 2001 740iL
different headlight ??
I tried again this am. The thought occurred to me that the passenger turn signal/headlight may be a different model than the driver's side. The previous owner did have a small accident on the passenger side, and the "headlight" was changed to the clear version. I have seen some of these headlight/turn signal lights, are they an "all in one" type, and would I be able to remove it the same way as a non-all in one, or do I need to remove the entire headlight to change (if at all possible) the turn signal. I stuck the screwdriver in the drivers side to see what the screw "felt" like. It was very easy to access, and I found the screw head almost immediately, that's not the case with the driver''s side at all. Wadda think ?
2001 E38 740iL Orientblue / Beige
1995 E38 740i Silver/Grey
