Originally Posted by douggie
But at the meantime, you can try this throttle adaptation reset procedure:
1. Keep your foot off the brake and hit the start/stop button.
2. Hold the gas pedal down (all the way down) for 5 seconds.
3. Switch off the car while holding the pedal down.
4. Done
You should see a slight improvement.
Sorry...confused here...in your reset procedure...the car won't start if you don't have foot on break. (Unless I am completely wrong) When do you turn the car on to perform Step 3?
2013 sDrive 28i X1
