Bimmerfest - BMW Forums - View Single Post - Rattling Noise From Transmission!!
Old 01-04-2013, 09:49 PM
Titansilber98M3 Titansilber98M3 is offline
Mein Auto: 98' m3 89' 325i
Help! I recently replaced the clutch, flywheel, pressure plate, throw-out bearing, pilot bearing and shifter with an F1 stage 1 clutch and ltw flywheel kit on my 98 m3 coupe and now I have a rattling noise coming from the transmission when the clutch pedal is not depressed, happens at idle and throughout all gears noise is kind of whiny at high rpm but not prevalent when pedal is being pushed. I thought it could be harshness from not having a dualmass flywheel but since it goes away when the clutch is disengaged it must be something else right?? Any help would be greatly appreciated!! Thank you!!
98'M3-MODS: FK Konigsport coilovers, Vorshlag camber plates, Eibach sway bars, ZHP Rack, Z3 SSK, F1 lightweight flywheel stg1 clutch, UUC system U catback, shorty headers, CAI, m50 manifold, fan delete, Mishimoto Rad + hoses.
89'325i-MODS: Vogtland Springs, Bavauto rear camber kit, xxr 002 wheels, 325is LSD, E30 m3 rear wing, Scorpion catback, CX aluminum Rad+ hoses, Fan delete, DTM ssk.(work in progress..)
