Thread: Fuel Filter DIY
Old 01-05-2013, 06:36 AM
X3-terrestrial's Avatar
X3-terrestrial X3-terrestrial is offline
Aficionado
Mein Auto: '05 X3, '02 M3, '91 E30
It is a bit involved, buy it sounds more complex than it is. Although I definitely would change 5 valve cover gaskets than one fuel filter. I did it myself in about two hours (had trouble removing the cap access to the tank) but once in there took 30 minutes to remove the old filter and put everything back together.
If you are not comfortable sticking your hands in dark, tight spaces and in contact with gasoline and gasoline smell, definitely have it done for that price! If I had to do it again I definitely had it done.
"If everything seems under control, you're just not going fast enough"
-Mario Andretti.
___________________
River City Bimmers BMW CCA
2005 X3 3.0i ZPP, Htd seats, Htd strng, Black Sapphire on Terracotta.
2002 ///M3 Coupe, Steel Gray Metallic on black leather, HK, three pedals.
1991 E30 325ic, AW, Black Leather, Black top, Three Pedals.
