Old 01-08-2013, 06:53 PM
roadkillrob roadkillrob is offline
Mein Auto: 325CIC, 335CIC
I am guessing that it is coated in some type of clear coating and that is what is scratched, but getting more agressive with it will most likely go through the coating (like using steel wool) and ruin it. I would start with some wet dry sand paper, 1500 and if that doesn't work, drop down to 1000 or 800, then work your way back up with 1500 then 2000 to get the sandpaper lines out and polish, but be careful, the coating is probably fairly thin.
Just start with the cheapest easiest piece to replace in case you sand through it!
2008 335i Vert Montego/Saddle/Grey Poplar
2013 Mercedes C63 AMG Obsidian Black/Black
2016 X5 M-Sport Mineral White/Mocha Design Package/Fineline Oak
