Bimmerfest - BMW Forums - View Single Post - Delayed alternator charging in cold weather
Old 01-09-2013, 12:40 AM
Tdgard Tdgard is offline
Mein Auto: 06 4.4i X5
Just went through this-this week. The length of time the light is on will probably get longer and longer. Once the battery gets too low your going to start getting all kinds of faults popping up. DSC/ABS inactive, trans failsafe, lights all over the dash, radio shuts off. Mine also only happened in the morning and i thought it had something to do with cold. However, it sits in a heated garage all night and the light would come on. Then I would go to work and it would get much colder sitting in the lot-no light.
I swapped the whole spinning electrical device instead of just a part to (hopefully) avoid having to pull it out 6 months from now when a bearing or brushes went out. All is now well.
