Bimmerfest - BMW Forums - View Single Post - Dreaded coolant leak!!
Old 01-09-2013, 07:44 PM
Yorgi's Avatar
Yorgi Yorgi is offline
Originally Posted by All-Or-Nothing View Post
Is an engine pull actually required???
If you don't install the aftermarket expanding All German Auto (AGA) pipe then you need to insert the OEM replacement pipe though the front of the engine. This requires lifting the engine out to slip the pipe in.
Dealer method is replacing a leaky $4 gasket with $9,000 of labour because BMW engineers did not select the best quality rubber for the o-ring on that pipe.
'04 M3 - track
'06 650i Cab - daily driver
'02 Highlander - kid hauler
'01 330Ci - winter beater
