Bimmerfest - BMW Forums - View Single Post - Dreaded coolant leak!!
Old 01-09-2013, 07:36 PM
All-Or-Nothing's Avatar
All-Or-Nothing All-Or-Nothing is offline
Woo Hoo FREE Donuts
Mein Auto: 2004 645Ci Convertible
Originally Posted by Yorgi View Post
If you don't install the aftermarket expanding All German Auto (AGA) pipe then you need to insert the OEM replacement pipe though the front of the engine. This requires lifting the engine out to slip the pipe in.
Dealer method is replacing a leaky $4 gasket with $9,000 of labour because BMW engineers did not select the best quality rubber for the o-ring on that pipe.
Seems like they could just remove the radiator vs lifting the engine out. I guess less labor charges if they did it that way...
