Very easy procedure
Start out with poping out the wood elements. Gently with even prying. Large head flat head screwdriver works good. Once you pull that off most everything is easy to figure out. Take care in pulling it away from the door as the connections for power windows and seat memory and the light atthe bottom of the door all have independent pigtails that need to be unclipped. Someone holding the panel 4 inches away from the door while you work your hand in there is the best bet. Make sure you power the window up to a certain point to have clearance to remove the regulator. Peronally if your doing the regulator I'd throw in a new motor. They tend to go eventually and this will save you the labor again.
