Bimmerfest - BMW Forums - View Single Post - New, need help!
Thread: New, need help!
Old 01-11-2013, 10:45 AM
deloreandude86 deloreandude86 is offline
Mein Auto: 1989 BMW 635csi
Originally Posted by hornhospital View Post
Gorgeous!
Welcome to the fest!
Personally I use Pelican Parts, AutohausAZ, and Rockauto for most of my replacement parts purchases. Check out the fest sponsors. too. There are several that are parts suppliers. ( ECS, Bimmerworld, TMS among many others)
Determine where the leak on the PS is and fix it, then flush and refill with Dexron III ATF (you didn't put power steering fluid in it, did you? )
Check fuses for the cruise control, then test to see if it's getting power.
Thank you for your help, the parts websites did help me. Yes there is transmission fluid in the resivoir, not power steering. I read somewhere that it may be a leaking hose? And I checked the fuse for the cruise, seems to be fine, any other possible problems?
Thanks again.
