Bimmerfest - BMW Forums - View Single Post - obd code HELP
Thread: obd code HELP
Old 01-11-2013, 04:56 PM
kupplung kupplung is offline
Mein Auto: 2009 BMW z4 sDrive35i
Unfortunately, it looks like your mechanic is lumping together two different fault numbering systems -- Pcodes and BWM Fault Codes (BMW-FC).
It seems like most of these codes are about cylinder misfires. 130 either means your o2 sensors are plugged in wrong (swapped) or it's p0130, upstream bank 1 o2 sensor.
Hope this helps. Others might be able to comment more on why both banks are misfiring.
#71 Misfiring with Cylinder Cutout Cyl 9
1057
203 Ignition Circuit Monitoring or (P0203) Injector circuit open, cylinder 3
72 Misfiring with Cylinder Cutout Cyl 10
62 Misfiring in Various Cyls
130 o2 sensors swapped, or (P0130) Lambda Sensor Pre Cat (Bank 1, Sensor 1)
136 Throttle Valve or (P0136) o2 sensor, bank 1, sensor 2
308 (P0308) Cylinder 8 misfire
309 (P0309) Cylinder 9 misfire
104 Fault Memory Error
306 (P0306) Cylinder 6 misfire
301 (P0301) Cylinder 1 misfire
303 (P0303) Cylinder 3 misfire
300 (P0400) Random/Multiple misfires
note at the bottom says total of 28 OBD II
