Bimmerfest - BMW Forums - View Single Post - Wow, was my alignment off !
Old 01-11-2013, 09:28 PM
ard ard is offline
Resident Curmudgeon
Originally Posted by ktono View Post
Looking at my spec sheet the BMW camber target and range is as follows:
Rear at -1.3 +/- 0.15
Front at -0.20 +/- 0.30
So -1.10 is slightly under the minimum spec for the rear camber. I doubt this will have a noticeable impact but as you know ard's the real expert. I am guessing the back tires will set in a turn a little quicker especially with some load in the back.
You need to recognize that those specs are in 'degrees' and 'minutes'
so the 1 with a little circle, then 30 and a ' symbol is "one degree, thrifty minutes"
Each degree has 60 minutes. So it 1', 2', 3', ....59' then 1degree00'. (no symbol here)
Anyway, your numbers look in spec. The 1deg30min minus 15 minute equates to 1deg15 min...you are spot on it looks like: 1deg30min and 1deg28min.
