Bimmerfest - BMW Forums - View Single Post - Extremely bad shaking on passenger side
Old 01-13-2013, 03:26 PM
kupplung kupplung is offline
Mein Auto: 2009 BMW z4 sDrive35i
First things first, are the lug bolts tight? If they are then you must have worn or deformed suspension parts over there. Replace all the parts with ball joints -- you did the tie rods, next do control arms and thrust arms. The stabilizer bar has bushings that you can replace, or it could be bent. My two cents, hope it helps.
