Old 01-13-2013, 03:33 PM
kupplung kupplung is offline
Mein Auto: 2009 BMW z4 sDrive35i
It happens to me more than I am comfortable admitting.
I assume this was happening since before you replaced the tie rods. Have you had an alignment done? Even if you matched the new tie rod length to the old one, the old one may have been set wrong if the problem existed then. If the problem popped up with the new tie rods, I would definitely suspect alignment.
