Thread: Heating issue
Old 01-14-2013, 11:44 AM
drivinfaster's Avatar
drivinfaster drivinfaster is online now
Mein Auto: rescued bmw's
wait....wut???
if you replaced the thermostat and bled the system properly, and are not overheating, then you should have plenty of heat.
you *could* have a restricted heater valve, or heater core, but you will need to use a proper infra red thermometer to get accurate temp readings.
otherwise you're going to be guessing.
and guessing gets expensive....
i say go back and double check the cooling system is bled. these are tough enough for experienced automotive technicians, so it has been my experience that almost 90% of diy'ers that have done this have not done it properly.
df
