To do the conversion, you will need a donor car. Preferably one that was wrecked from the side, but front or rear will be fine as well, provided the engine is in good condition and the driveshaft is still straight. You will also need to get the electrical components for ECU and so forth.
It is much better and "cheaper" if you had a wrecked donor car.
