Old 01-15-2013, 08:05 AM
HPIA4v2 HPIA4v2 is online now
Mein Auto: E60, E71, E92
Originally Posted by bimmerworld View Post
Seems like an odd question but where should I use my multimeter when measuring the voltage of my battery? I tried the jumper locations under the hood and was about to fry my multimeter. I got a spark and the multimeter cables were hot. Should I go through the hassle of removing the spare tire in the trunk and directly use the battery outlets there? Thanks for any advice.
NO!
I never had spark (rush current) testing voltage at charging terminal in engine bay.
You have either bad voltmeter or not in volt-measuring setting (my guess would be in current measurement setting), got it checked.
PS: volt-meter has high impedance so virtually no current flowing between measurement leads. amp-meter on the other hand, has low impedance in between leads.
