Old 01-15-2013, 01:22 PM
Fishful Thinking Fishful Thinking is offline
Mein Auto: '04 325ci
Originally Posted by cwsqbm View Post
OK, I've learned a few things since my last post. Most recently, the frame-less windows on the coupe suck when the car has been coated in ice. The windows couldn't move down enough to open and close the doors properly. Getting the door open wasn't too hard, but I couldn't close it all the way from inside the car. I drove to the gas station this morning with a door ajar indicated until I was able to use their antifreeze and wiper to soak the rail until the window moved.
A very easy solution to this is, as you park the car in the evening, you roll the window down 1/4" or so. Just enough to clear the frame, but not enough to move the window out of contact with the seal. I do this whenever there's a threat of a freeze, and it works like a charm. If I remember....
