Old 01-15-2013, 05:32 PM
flash_n flash_n is offline
Mein Auto: 745Li
Originally Posted by Piers1989 View Post
AFAIK leak from wires = mechatronics sleve
Had it replaced at the Indy yesterday for about 250.
AT Plug adapter sealing sleeve - 24 34 7 588 725
Pan Gasket - 24 11 7 571 204
5Qts Transmission fluid
Hope this helps!
Silver 2004 BMW E66 / 745Li (DIYs):
ASK, Logic 7, blower, battery, guibo joint, active stabilizer bar bushings, diff oil, tranny sw update, vacuum pump gasket, window lift, a/c compressor, washer fluid reservoir, belt tensioner and deflector, crankcase vacuum hoses, crankcase vents, solenoid gaskets, headlight overhaul, ISM, hood lifts, driver mirror, sway bar end links, rear fog lamps, headlight washer, headlight vertical aim, VCGs
next up: P0492
