Old 01-15-2013, 10:57 PM
MikesE39's Avatar
MikesE39 MikesE39 is offline
Mein Auto: 03 530i Loaded
ok the problem is that black plastic stretches and unplugs the coil that is inside it from the motor. so all you have to do is cut off 1 inch or so, or maybe less of that black plastic and join the 2 ends of the black plastic together with a hose clamp or something like that. then plug the coil that is inside the black plastic where it belongs. nothing can go wrong as long as you only cut the black plastic.
