Bimmerfest - BMW Forums - View Single Post - Transmission leak!!!! Help
Old 01-16-2013, 03:33 AM
flash_n flash_n is offline
Mein Auto: 745Li
Good luck.
Please take some pictures and consider opening a DIY thread, if you want.
Silver 2004 BMW E66 / 745Li (DIYs):
ASK, Logic 7, blower, battery, guibo joint, active stabilizer bar bushings, diff oil, tranny sw update, vacuum pump gasket, window lift, a/c compressor, washer fluid reservoir, belt tensioner and deflector, crankcase vacuum hoses, crankcase vents, solenoid gaskets, headlight overhaul, ISM, hood lifts, driver mirror, sway bar end links, rear fog lamps, headlight washer, headlight vertical aim, VCGs
next up: P0492
