Originally Posted by Red Lined
In most cases, it will be a ~$30 difference unless BMWFS inflates the residual on the 320. The numbers don't lie...build a few and plug the numbers in a lease calculator. Even in BJ's over-exagerated example above the difference is a little over $40 a month.
Isn't this always the case with a new model? Lease numbers will improve once it's out for a while. And you'll have a higher percentage of buyers in a cheaper model.
"When you were born, you cried and the world rejoiced. Live your life so that when you die, the world cries and you rejoice." - Cherokee Expression
