Old 01-17-2013, 10:35 AM
tim330i's Avatar
tim330i tim330i is offline
Bimmerfest.com Founder
Mein Auto: Ti Silver 03 M3
F30 320i vs 328i engines - Part number comparison
BMW has just announced a new entry level F30 3 series, the 320i. The 320i shares the same N20; TwinPower single turbo, twin scroll, 2.0 liter inline 4 cylinder engine as the 328i. The 320i is factory rated at 180 hp at 5,000 RPMs and 200 lb-ft of torque from 1,250 RPMs. Stacked next to the 328i with 240hp at 5000 RPMs and 255 lb-ft of torque from 1250 RPMs and the obvious question is what is the difference in the two engines.
The first obvious answer is there is something in BMW's DME control software that limits the power, most likely by limiting boost pressure, on the 320i. That appears to be true as both the 320 and the 328 use the same DME hardware (PN - 12148604210) and the same engine control system MEVD 17.2.9. With a software tweak the likely difference between the 320i and the 328i we go in search of other changes that might limit the 320is ability to make the same power the 328i N20 puts down.
Read more about the 2013 BMW 320i entry level 3 series
The next easy target is the intake, exhaust manifold and turbo. Surprisingly they turned out to be the same part number. In fact the 320i and the 328i share the exact same part numbers for a majority of the engine components.
Shared engine components between F30 320i and 328i
  • Cylinder head - PN 11127624778
  • Connecting rods - PN 11247624616
  • Crankshaft - PN 11212212762
  • Intake manifold - PN 11617588126
  • Air box - PN 13717597589
  • Air filter - PN 13718507320
  • Intercooler - PN 17517618809
  • Radiator - PN 17117600520
  • Throttle body - PN 13547588625
  • HPFP - PN 13517584461
  • MAF - PN 13627602038
  • DME/ECU - PN 12148604210
  • Exhaust manifold/turbo - PN 11657642469
See what is missing in the above list? The difference in the 320i and the 328i is the pistons. While both have a 10:1 compression ratio the 320i has a different part numbers for the pistons then the 328i. What that exactly means in terms of the ability to boost the turbo pressure and get 328 horsepower from your 320 is not yet known.
Stay tuned as we continue to sift through BMW's technical documents searching for an answer.
More about F30 320i vs 328i engines - Part number comparison
2013-BMW-NAIAS 12013-BMW-NAIAS 22013-BMW-NAIAS 32013-BMW-NAIAS 42013-BMW-NAIAS 52013-BMW-NAIAS 62013-BMW-NAIAS 72013-BMW-NAIAS 82013-BMW-NAIAS 92013-BMW-NAIAS 10
