Originally Posted by av98
Yep I did your statement wasn't very clear. Which still makes the important specs on the engine valid- bore, stroke, compression- what are they?
Data from bmwusa configurator shows that bore, stroke, compression are the same on both cars.
328i:
Engine
Type/cylinders/valves per cylinder
TwinPower Turbo/Inline 4/4
Displacement
1997 cc
Bore/stroke
3.3/3.5 inch
Nominal output hp/rpm
240/5000-6000
Max. torque lb-ft/rpm
255/1250-4800
Compression ratio
10 :1
320i:
Engine
Displacement
1997 cc
Bore/stroke
3.3/3.5 inch
181/5000
184(250) / 1250-4500
Compression ratio
10 :1
Reason: fixed copy-and-paste error
