01-18-2013, 12:55 PM
Mein Auto: 2004 BMW X3 3.0 Auto Tran
Originally Posted by mlukas161
Did you replace the expansion tank cap with a new one or reuse the old one?
Update: I think the leak was because of excessive coolant. I got the new cap and I took the old one out.
The first thing I noticed was that the needle was at its highest point no matter what. Meaning, that it doesn't take much for the expansion tank to be full.
I ended up replacing the cap anyways because I noticed that the new cap had two rubber seals that were in far better condition that the old cap. I believe the leak near the tank is now gone.
However, I notice a very minuscule coolant leak from one of the thermostat hoses. I haven't been able to check exactly where it's coming from but if you are facing the car, I think it's the hose LEFT from the thermostat. (If you are sitting in the car it would be the hose that is connected on the passenger side)... It's not a major leak but something to keep an eye on.
I am predicting I will have to do the full engine cooling system maintenance in the spring/summer. I just gotta get the parts first, part of me does NOT want to replace the radiator though. It's too much work imo to take it out but I haven't decided.
