Hi
Would you please help me with the seat occupancy sensor?
I did use NCSXEPERT to upload the SSBF module file.
Then I modify the file FROM: BELEGUNGSERKENNEUNG_BF oc3 To: BELEGUNGSERKENNEUNG_BF keine_sbe, Load the file back to SSBF module.
After that the light for Passenger Airbag went off for 20 sec and then the light come back. So then I reset the SSBF module with INPA. Went back to NCSEXPERT upload the SSBF module again and notice that the file is back to original, the keine_sbe is missing and the OC3 is back. I did it 2 more times with the same effect.
Can somebody help me with this?
2006 BMW 750i
GURTSTRAFFER_BF
aktiv
ZK_MIN_GURTSTRAFFER_BF
wert_01
ZK_MAX_GURTSTRAFFER_BF
wert_01
HALLSCH_EIN_GURT_SSBF
hall_ein_gurt_an
STROMGR_KS_HSCH_ZU_SSBF
wert_01
INDEXTAB_FC_SSBF
wert_01
STROMGR_AUF_HSCH_UB_SSBF
wert_01
CHECKCTRLTAB_SSBF
wert_01
ZK_MIN_AKTIVEKOPFST_BF
wert_01
ZK_MAX_AKTIVEKOPFST_BF
wert_01
TIMEOUT_ID_UEBERW_SSBF
wert_01
VERZOEGERUNG_SBE_SSBF
wert_01
LINKS_LENKER
linkslenker
PDC3_ERR_LIMIT_SAT
wert_01
GURTSCHLOSS_BF
aktiv
ALGOPARAM_SSBF_EAM
wert_10
AKTIVE_KOPFSTUETZE_BF
aktiv
oc3
ZK1_ZF_SSBF
vom_ss_nicht_beeinflusst
ZK2_ZF_SSBF
vom_ss_beeinflusst
