Old 01-18-2013, 08:44 PM
tatarogl tatarogl is offline
Mein Auto: n/a
Ok, I was not able to open the hood by disassembling the latch lever from the driver seat. I then pulled the cable with pliers and it popped the hood. I open the plastic enclosure holding the two wires together and found a broken plastic peace which I assume was holding the wire coming from inside the car.
I will replace the plastic, but do you guys think I should also replace the wire(s)?
ID:	358304   Click image for larger version
ID:	358305   Click image for larger version
ID:	358306   Click image for larger version
