It sounds like the light control module (LCM) is defective. Never had to fix mine but read about the problems. Try: Remove; terminal and earth clean and refit B4 you replace it. Also check out the wires connectors and earth points in the boot. You could find the problem or fix it with out seeing anything wrong.
Current:
Previous:
