Old 01-19-2013, 02:17 PM
chrisn7 chrisn7 is offline
Mein Auto: 750iL
Its very common on all cars for a slime to form in washer reservoirs. Before spending on new pumps etc, check out the reservoir for clogged outlet filters. There is also a filter on the reservoir for the intensive headlight washer pump, which falls off if the pump is removed, so that unfiltered fluid can then block the headlight washers too....Its a very easy job indeed to remove this for cleaning/checking
