Bimmerfest - BMW Forums - View Single Post - Exterior Bulb Warning light on but no deab bulbs?
Old 01-21-2013, 12:08 PM
nikasp nikasp is offline
Mein Auto: E83 LCI (2007)
Will do, but why the heck does the same bulb function when I turn on the turn signal? Does it have two set of wires inside. My brain is mush right now (stressed out about work stuff).
Seems as if there is a 5W bulb that should sit on top of the high beam. Could have sworn that the left "parking" light is the same as the turn signal. Will check later or tomorrow. Attached the manual that says the parking light is 5W and the turn signal is 24W which sounds pretty reasonable.
Originally Posted by Supercourse View Post
Just replace the bulb.
Fuses blow when there is a fault that needs to be addressed before putting a new one in- it's not that fuses just wear out like light bulbs.
(But they can work loose in rare cases.)
Not that you need worry about it now, but the panic brake light cannot be tested when stationary.
It is activated by a deceleration rate and involves the ABS.
