Old 01-21-2013, 06:29 PM
boramkiv's Avatar
boramkiv boramkiv is offline
Propellers Up Front
Originally Posted by moi101 View Post
Hello and thanks for you input. I have managed to changed the radiator and spider hose since that's the only way to get the top portion. Now, I noticed that water is still leaking. However, this seems to be new. I looked under the car and there's a plate where the oil pan sits. Just behind that, i see a few hoses where water seems to be leaking from the top. This to me appears to be something behind the motor. Has anyone experienced this ? There is no visible leaking occurring on the top that i can see.
If you have a leak behind the motor, it could be time to change your valley pan gasket accumulator or pipe orings/ gaskets. Basically the intake manifold needs to be removed to get to that stuff if you are getting an unknown leak from the back somewhere.
It's very difficult to see the leaking gasket from the top under the manifold.
http://realoem.com/bmw/showparts.do?...36&hg=11&fg=35
It's a bit of work, but possible. If this is the route chosen be prepared to change a lot of parts as you get in there.
http://m.youtube.com/#/watch?v=0E1vFrxQcqk
